Canon IR6000 error E-000732001
  • copiman
    • Sep 2011
    • 861
    [Error Code] Canon IR6000 error E-000732001
    I am not a Canon tech but have been a tech for 30 years. Trying to help a friend. What is the error code E000732001? Is there a reset and how? Need a manual. can swap Panasonic or Ricoh manuals.
  • Paul 75
    • Oct 2008
    • 97
    Re: Canon IR6000 error E-000732001
    Try these to start :
    E732
    Main cause The connector has poor contact. The reader controller PCB is faulty.
    Mode of
    Detection
    0001 The main controller PCB has detected an error in the communication
    between the reader controller PCB and the main controller
    / Model :
    iR / iR5000, iR5000d, iR5000i, iR5020i, iR5020N, iR6000, iR6000d, iR6000i, iR6020i, iR6020N
    Error Codes
    E732
    The Error points to a misscommunication between the Reader and Main controller
    There was no 24v at the reader controller ,because there was no 24v output from the power supply
    Traced the fault to a faulty HVT transformer, when it was disconnected the 24v supply was normal
    Oh...... I can't copy at the moment then ? !!!!!!
