DADF-P1 Service Guide
  • LennoxD
    • Sep 2011
    • 82
    Can someone help me with service guide or spec sheet for canon document feeder DADF-P1
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 4964
    Re: DADF-P1 Service Guide
    Hi. What's wrong?
    Practice makes perfect
    If you want something done right, you have to do it yourself
    • LennoxD
      • Sep 2011
      • 82
      I wanted to know if the DADF-P1 can scan A4 documents. Have a customer who uses only A4 and notice that when they copy using A4 size originals, piece of the documents is not copied.
      • zoraldinho
        • Mar 2008
        • 4964
        Side Registration Adjustment
        1) Place the test chart on the DADF and take a copy of it.
        2) Compare the side registration on the test chart with that on the copy. Perform
        adjustment if required.
        If the image is shifted forward, increase the value.
        If the image is shifted rearward, decrease the value.
        Adjustment step: 0.1 mm
        3) Enter the service mode.
        Press the User Mode key " ", 2 key, 8 key, User Mode key " " on the
        operation panel of the host machine.
        4) Using the arrow keys on the operation panel, display "#SCAN".
        5) Press the OK key.
        6) Using the arrow keys on the operation panel, display "#SCAN NUMERIC".
        7) Press the OK key.
        8) Using arrow keys, select 41.
        9) Using numeric keys, change the value to determine the optimum value.
        Press the OK key. (Default: 35)
        Leading Edge Registration Adjustment
        2) Compare the leading edge registration on the test chart with that on the
        copy. Perform adjustment if required.
        If the image is shifted leftward, decrease the value.
        If the image is shifted rightward, increase the value.
        8) Using arrow keys, select 42.
        Press the OK key. (Default: 220)
        Reading Position Adjustment
        1) Enter the service mode.
        2) Using the arrow keys on the operation panel, display "TEST MODE".
        3) Press the OK key.
        4) Press the 2 key. "SCAN TEST" appears.
        5) Press the 3 key. "SHEET POS ADJ" appears.
        The optical system starts scanning. Several seconds later, automatic
        adjustment
        of the reading position finishes and "OK" appears.
