Control Panel Inverter - Canon iR3245
  • CopyX
    • Jun 2025
    I am replacing the inverter for a iR3245. What in anyones experience is the proper way. The service manual/NAVI does not show a cross section. I have the parts exploded view however it looks like there is a way to simple pull out the finisher and access the inverter board on the underside of the control touch panel.
  • charm5496
    • 2387
    Re: Control Panel Inverter - Canon iR3245
    remove the control panel from the machine and flip it over. take it apart to remove the board and then reassemble. It only takes around 15 minutes tops.
