Timing for the gears of Main Drive Unit Ass'y (Gears Inside) for Canon Isensys MF8450
  • mark121381
    • Jul 2011
    • 85
    [Misc] Timing for the gears of Main Drive Unit Ass'y (Gears Inside) for Canon Isensys MF8450
    Can anyone help on this.I accidentally open the Main Drive Unit Ass'y for this machine. Is there timing on gears because when I try to close it , I'm in doubt that the gears are out of timing. Do you have idea on this? I already checked the manual but I can't find the timing for the Main Drive unit. The Timing that I need to know here is inside of the Main Drive Ass'y. Thank you in adavance
  • teckat
    • 16084
    Re: Timing for the gears of Main Drive Unit Ass'y (Gears Inside) for Canon Isensys MF
    Removing the Main Drive Assembly
    Shift down the drive release lever [1], and remove the gear [2].
    Re-mounting the main drive assembly
    When mounting the main drive assembly, be sure to fit the gear [2] as shown with the drive release lever [1] in down position (i.e., with drive engaged).
    At this time, be sure that the position of the gear is correct so that it is fully engaged with the gear of the drive release lever.
    • mark121381
      • Jul 2011
      • 85
      [ATTACH=CONFIG]16671[/ATTACH]
      [ATTACH=CONFIG]16670[/ATTACH]
      Hello Sir Teckat,
      Good day, This is not the model that I've been talking to. The model of my machine is Canon MF 840 or Canon IRC 1021i
      I appreciate your response. and also Sir for your info. The Assembly of Main Drive Unit Im talking about not the installation process attach going to the machine. Thank you very much, hope that you have information on this. cause on the manual it is replaceable by whole assembly. thank you again sir
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 4999
        Alignment of the gears in the main drive unit
        When installing the main drive unit, the corresponding gears of the host
        machine [A] need to be interlocked in order starting from the top of the 5
        gears.
        Following shows the procedure:
        Align the gear [5]'s elongate hole [2] with the triangle [1].
        Interlock the teeth of the gears [5] and [6] so that the holes [3] of the
        gears will lie right next to each other.
        Interlock the teeth of the gears [6] and [7] so that the holes [4] of the
        Interlock the teeth of the gears [3] and [4] so that the holes [1] of the
        Interlock the teeth of the gears [4] and [5] so that the holes [2] of the
        • teckat
          • 16084
          Originally posted by mark121381
          Hello Sir Teckat,
          sorry I posted on wrong model/ getting old> need to update glasses>
          zoraldinho - i believe has your answer
          • mark121381
            • Jul 2011
            • 85
            What I mean here is the exactly inside Main Drive unit Ass'y. Now my machine is working now. what I did is I compared it to other Main Drive unit Ass'y. Thank you very much for all response, I really really appreciate it. Thank you Sir Teckat and Sir zoraldhino, till next issues
            • zoraldinho
              • Mar 2008
              • 4999
