can someone explan what is HV-SP ( SPN1 & SPN2) CANON IR6000
  • hsh6049
    • Jul 2012
    • 64
    can someone explan what is HV-SP ( SPN1 & SPN2) CANON IR6000?
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5018
    Re: can someone explan what is HV-SP ( SPN1 & SPN2) CANON IR6000
    COPIER>ADJUST>HV-SP>SP-N1 (Use it to adjust the output for the
    first side of a double-side print or for a single-sided print of plain paper.)
    COPIER>ADJUST>HV-SP>SP-N2 (Use it to adjust the output of the
    second side of a double-sided print of plain paper.)
    If the RAM on the DC controller PCB has been cleared, enter the value indicated
    on the service label.
    COPIER>AJDUST>HV-SP>HVT-SP (Enter the offset value for the separation
    high-voltage output of the high-voltage unit.)
    Enter the value indicated on the label attached to the new high-voltage unit
    if the RAM on the DC controller PCB has been cleared or the high-voltage
    unit has been replaced.
    COPIER>ADJUST>HV-SP>D-HV-SP (Use it to enter the offset for the
    separation high-voltage of the DC controller PCB.)
    Enter the value indicated on the new DC controller PCB if the RAM on the
    DC controller PCB has been cleared or the DC controller PCB has been replaced.
    • hsh6049
      • Jul 2012
      • 64
      thanks for the explanation.....i found my machine setting for spn1&spn2 is -180. but the factory setting suppose to be -83 for both. i don't understand why the technician change the setting. what should i do if i found the image copy is light?
      • teckat
        • 16083
        Check to see if the preconditioning leds are coming on. If they are not on, check the voltage for the preconditioning leds. It should be about 17 - 20 vdc. If you don't have the voltage or it is very low, replace the DC Controller. If the voltage is ok, then replace the preconditioning leds
