IR6000i error code
  • Henry
    • Dec 2007
    • 18
    IR6000i error code
    Hi everyone!
    What does E000584-0003 stands for? It happened to me three times while printing. It needs to re-start the unit to get back to normal operation.
  • lkrsardis
    • Dec 2007
    • 316
    e584
    That is an error code for the finisher you need a tech.
    Like the United States Postal Service It's a miracle it works!
    • Henry
      • Dec 2007
      • 18
      Any particular item in the finisher where the possible trouble occured? I'd like to check it myself and see if I can fix the problem. Thanks for your help.
      • lkrsardis
        • Dec 2007
        • 316
        error code
        repeat, you need a tech.
        • OtherTech
          • Aug 2007
          • 94
          Probably the shutter switches. Have seen wire break inside insulation going to front switch.(behind upper cover)
          • Henry
            • Dec 2007
            • 18
            good day, just have dismantled the finisher assembly, I noticed some screws were not tighten properly at the tray holder bracket causing the mechanical lifting device to jam. After I re-tigthen it, it worked well and no error occured again! Thanks for your help.
