canon IR 3235 toner waste
  • buffalotech
    • Aug 2025
    [Misc] canon IR 3235 toner waste
    hopefully someone can answer this easy question. Where exactly is the waste toner bottle located? I couldnt find it anywhere. Any help would be greatly appreciated ! thanx
  • teckat
    • 16083
    Re: canon IR 3235 toner waste
    Removing the Waste Toner Container
    1) Open the front cover.
    2) Turn the lock lever to release the lock of the waste toner container.
    3) Remove the waste toner container.
    4) Remove the lid attached at the front of the waste toner container, and then cover the opening of the container with it so that the waste toner does not spill out.
    • jarwil
      • Jun 2009
      • 61
      You will need a screwdriver. Front cover doesn't just pull down. Two screws holds the cover on
