Haven't used this machine in a while, can anyone tell me what this error codes is and whether its worth fixing please
CLC 3220 Error Code E000751-1301
Tags: None
Re: CLC 3220 Error Code E000751-1301
The machine is checking for the presence of toner. After 3 attempts the machine will go into the error. In this case, the yellow toner tube needed to be replaced even though the machine did not indicate to do so.
CLICK ON PIC FOR BETTER READ
in moth balls/ u need to do inspections/maintenance**Knowledge is time consuming, exhausting and costly for a trained Tech.** -
matrixgav
Thank you very much, it was a kantun toner that they sent in instead of canon, replaced today with canon, everything perfect
E751-1301 means there is an issue with the toner system.
[ATTACH=CONFIG]16728[/ATTACH]
in moth balls/ u need to do inspections/maintenanceComment
