Need Help: iRC3380 Correction of faulty images
  • ericang
    • Dec 2010
    • 39
    [Misc] Need Help: iRC3380 Correction of faulty images
    Hi there..
    i have a irc3380 with faulty images output on yellow n black dev assembly
    below attachment are the sample of my test printout on service mode...
    these are the part that i tried to replace but it fail...
    -Drum
    -Primary n Secondary Charger
    -Cleaning Blade
    -ITB unit with new blade
    ANyone hav any idea pls help..
    Thanks^^
  • teckat
    • 16083
    Re: Need Help: iRC3380 Correction of faulty images
    first off> u have a paper feed registration issue> enlarge document to see issue
    Perform in LEVEL 2 > COPIER> FUNCTION> CLEAR> REG
    power off/on printer--then>Clean the patch sensors and perform an auto color correction mismatch ( corrects Color Registration issues)> then run a full auto gradation>
    To perform an auto color correction mismatch, Enter Additional Functions Adjustments and Cleaning. On page three select auto color mismatch correction.
    If Auto color correction mismatch is not an option, be sure to update the firmware to the latest version. To clean the patch sensors manually actuate the solenoid to open the shutters and wipe the sensors with a dry lint free cloth.
    Below is a photo of the solenoid and shutters that cover the sensors.
    second>>
    the image ends drop offs are the same on all black patterns (match)/ same on all yellow patterns(match)
    is this the same image issue before u replaced parts ????
    did u replaced the yellow and black drums ?? were they Canon OEM's
    did u touch the laser unit ???
    • Rachid.Akli
      • Oct 2011
      • 595
      When the drums get used, they have a tendency to loose toner that will drop on the laser procting glasses. This may result on a poor print quality or E020 error code. Use the laser cleaning tool or take out the laser and clean it.
      Good luck.
      Rachid
      "Find a job you love and you’ll never have to work a day in your life." Nagy's father
      • ericang
        • Dec 2010
        • 39
        Teckat>>
        yes.. i have tried to replace with a OEM drum n blade but turn out the same problem..
        change black n yellow assembly n it works fine......
        n even test on other machine with these 2 problem assembly n same problem too..
        thanks for those suggestion...
        • ericang
          • Dec 2010
          • 39
          Good luck.
          Rachid
          Yes... i did check on the laser unit for dust n toners.. n clean it with blue color with cotton end tool to clean the glass.. still no hope..
          today i try on the test print pattern.. the missiing pattern of the black is even worse now...
          • Canon.Tech
            • Mar 2009
            • 335
            • ericang
              • Dec 2010
              • 39
              we hav call up a canon tech in my area n after they inspect the the attached document they said it most probably having issue with the developing cylinder or the carrier(developing)they will send someone to my office with the cost of RM200..let see what they can do.... hopefully able to solve this problem rather than replacing with a new assembly becoz i wanted to know the problem...thanks guys~~
              • teckat
                • 16083
                "yes.. i have tried to replace with a OEM drum n blade but turn out the same problem.. change black n yellow assembly n it works fine...... n even test on other machine with these 2 problem assembly n same problem too.. thanks for those suggestion... " slow down a bit u mean it now works fine / after replacing units again??? you tested the black and yellow dev. units on another printer and they show same problem ? why are u calling for service ??
                • ericang
                  • Dec 2010
                  • 39
                  Yes sirr...I replace both black n yellow assembly from other machine n the pattern just fine.This prove that this is the problem with the assembly n not the machine itself. Been having this problem for 2week n we could not fix it n we got no choice to call a real Canon TechSorry sir becoz my English is bad
                  • teckat
                    • 16083
                    Bad OEM Units can be returned for credit / service tech can't repair them
                    • ericang
                      • Dec 2010
                      • 39
                      Sir...
                      those bad unit has expired for warranty..
                      the canon tech came this morning n they recommend that we change a new assembly for black n yellow...
                      i guess this is the only choice to solve this..
                      Again... thank again for everybody who tried to help me...
                      thank thank thankss
                      • Canon.Tech
                        • Mar 2009
                        • 335
                        • nghialuuvn
                          • Jan 2008
                          • 67
                          Hi All,
                          This symptom happens very often on iRC3380 series.
                          The reason is seal that locate under drum (prevent waste toner in drum unit from come out),
                          it easily come out if technician rotate drum wrong direction and then it will block laser shine on drum surface.
                          As in result, you will have printout like attached file early.
                          Replace whole drum unit will resolve problem, however that way is costly.
                          The best solution is to reinstall that seal properly.
                          • ericang
                            • Dec 2010
                            • 39
                            Originally posted by nghialuuvn
                            Hi All,
                            Hi sir...
                            thank for the info....
                            just to make sure...
                            The seal that you mention is it the one that attached together with the waste toner unit which look a bit plastic transparency
                            like?
                            if this is it.....
                            i did change the said item using another assembly unit n it still the same...
                            The Developing carrier is the only thing i haven't change because i couldn't find it on the market... everybody selling the whole drum unit...
