After firmware update(Ver. 5.01 to Ver. 80.04) LCD goes black.
  • huli
    • Nov 2009
    • 8
    Hello.
    After firmware update(Ver. 5.01 to Ver. 80.04) LCD goes black.Firmware update procedure completed without error's.I didn't update BOOT, only SYSTEM.
    Any solution?.
    Thanks.
  • teckat
    • 16083
    Re: After firmware update(Ver. 5.01 to Ver. 80.04) LCD goes black.
    Originally posted by huli
    Hello.
    Any solution?.
    Thanks.
    what is the model ??????????????????????????????
    • huli
      • Nov 2009
      • 8
      Canon IR1018.
      • teckat
        • 16083
        Canon IR1018.
        no iR1018 in US / remove and re-seat boot/
        why did u skip boot/ do u have a tech pub on that firmware used ?
        • huli
          • Nov 2009
          • 8
          It's like imageRUNNER 1025 (Canon U.S.A. : Office Equipment : imageRUNNER 1025).
          I remove and re-seat boot. When switch on the copier, LCD become black and main motor rotate for few second.
          I try short-circuit JP141 header (image processor PCB) and switch on copier, to activate Download Mode, but copier don't switch on.
          • teckat
            • 16083
            try this ___
            Press and hold the 2 key only on the ten key pad and then power on the copier.
            This puts the machine into the download mode. The screen will display Initializing.... for a few moments and then display Download Standby.
            This method of getting into download mode can be used to recover a failed upgrade or to try to flash a machine that will not boot up and come to ready.
            used on 1023 series/ may function on yours/
            • huli
              • Nov 2009
              • 8
              Thank you very much.
              I will try this solution.
              • zoraldinho
                teacher-guide-expert-guru
                • Mar 2008
                • 4999
                Wlaa 80.04 is beta version.Use 68.01 supported by Canon.
                • huli
                  • Nov 2009
                  • 8
                  Thanks zoraldinho. I have WLaa60.03 and WLaa50.01. Did anyone has try to activate Download Mode with short-circuit JP141 (image processor PCB) and switch on copier?.
                  • teckat
                    • 16083
                    unit must be on before procedure- With the unit powered on, short the two pins at JP141 on the Image Processor Board. This can be done with a screwdriver or an alligator clip. This will reset the machine so system software can be re-flashed.
                    • teckat
                      • 16083
                      When upgrading to ver.60.03, you do not need to perform All Clear, so all user data remains. Therefore, upgrade the version using normal procedures. U need to do the BOOT ROM FIRST when u get in download mode again Note: Before using System Software v60.03, make sure to install the BootROM ver.60.03 first. 2. Make sure to turn OFF and ON the main power between each download. 3. Using Service Support Tool, install System Software ver.60.03. 4. Turn off and on the device power.
                      • huli
                        • Nov 2009
                        • 8
                        I try short-circuit JP141 (image processor PCB) with the unit powered on, but nothing happen, the LCD still be black.
                        • teckat
                          • 16083
                          re-seat connector J318 on the Image Processor and connector J1701 on the operation panel. did you>>>>try this ___ Press and hold the 2 key only on the ten key pad and then power on the copier. This puts the machine into the download mode. The screen will display Initializing.... for a few moments and then display Download Standby. This method of getting into download mode can be used to recover a failed upgrade or to try to flash a machine that will not boot up and come to ready.
                          • Elettrozeus84
                            Hi,
                            I have the same problem of huli.
                            Has anyone found a solution?
                            Thanks in advance...
