5185 colour fade
  • teckat
    • 16083
    #16
    Re: 5185 colour fade
    Originally posted by Fer
    I'll have another for ya.
    That static elliminator looks pretty dirty. Waste toner is leaking from the waste toner feed screw and soils the area around the itb cleaning blade. Take out the cleaning blade and y drum and have a look. Remove the waste toner feedscrew and vacuum that mess, before is getting rock hard. If it keeps soiling replace the feed screw.
    have replaced a few broken feed screws in these 3220's / what a mess/& job to replace
    • nogood boyo
      • Mar 2012
      • 156
      #17
      wow,
      that is a lot of great advice, i really appreciate all of the input.
      thanks.
      • V-P
        • Apr 2011
        • 679
        #18
        I bet on the drum units.
        Till recently we used to throw away these drum units and replace with new ones.
        Now we are "reviving" them with new dev. material and new drum cylinder.
        What can I say : Crisis
        • teckat
          • 16083
          #19
          good news/ but in a fast pace large USA city , u have no time/or space to revive /
          what is the total cost on one unit - rebuild time + parts + testing + performance + shipping + $$$$$
          vs a new on hand unit ready to go--
          • Fer
            • Nov 2009
            • 267
            #20
            Wat brand drums and what starter are u using? Are they good in the field?
            • V-P
              • Apr 2011
              • 679
              #21
              I just started testing them on a few CLC5151 units and iRC3580 units.
              So far so good (just some minor issues)
              Regarding cost :
              Dev. Material = 25-30 USD per unit
              New Drum = 25-30 USD per unit
              Chip = 3-5 USD per unit
              __________________________________
              Total = 60-70 USD / Unit
              Reviving time : 15-30 min
              I will update when I have long time feedback from field.
              It is experimental phase for us too.
              • nogood boyo
                • Mar 2012
                • 156
                #22
                Originally posted by teckat
                one thing I learned about these models/ do not rely on % indicators used for DRUMS
                look at the meter reading between drum replacements & look to see what the customer is printing
                it's the % amount of toner on paper coverage
                remember these are tested at 5/6% text coverage for those Drum % avg monthly numbers in guide
                Yeah, I have one machine, the drums fail at about 450... and another machine, the K-drum has failed at about 150
                How do i check the counter settings... does this machine read a an 11X17 as one print? or two? How do you check to see the average percentage of toner on paper coverage?
                • teckat
                  • 16083
                  #23
                  THIS IS 6% COVERAGE
                  SEE PDF
                  6%.pdf
                  drum counter==none on this series/ it's all about coverage and paper type
                  u can set printer to count a double click for 11x17 for billing purpose
                  To enable this feature you must set one of the Soft Counters to ( 102 ) Total 2 in Service Mode.
                  • nogood boyo
                    • Mar 2012
                    • 156
                    #24
                    okay, that makes sense.
                    i was going off the life on the p-prints... last page
                    MISC
                    *-DRM-LF
                    one machine would reach 400-450 and another reaches around 190 - 210 and fails.
                    • teckat
                      • 16083
                      #25
                      MISC
                      *-DRM-LF
                      had a few customers that were printing at 70/80 % at full color letter size coverage > Drums did not last at all past 130/140% usage
                      • V-P
                        • Apr 2011
                        • 679
                        #26
                        I have a silly question, since we are in the subject:
                        Does the magnetic iron roller (shaft) loose its magnetic power over the time ?
                        (I mean the one inside the drum unit)
