Hi, Im working on this problem for almost whole day but i still cannot fix it that if we using the platen glass for copying its working fine, but after that when we use ADF it show at the screen there "remove the original from platen glass". Theres nothing on platen glass. Once we insert the original on ADF it will always show that massage on LCD Screen. I've done cleaning the IC, TLP1241, PHOTO-INTERRUPTER (See picture) ir7200 ADF.pdf , changed ADF Controller PCB, cleaned the platen glass, cleaned scanner mirror & lamp and reload the firmware using SST but the problem still the same.
Please Will appreciate if someone give me some clue on it?
