Hi Chaps. I've got to visit a 2030 which one of my engineers if having issues with. Constant E003 error . New fixing assy put in and then DC con replaced. Previously machine had been showing constant shut side door error which was put down to the switch not being made , but he thought it was the AC driver. Im gonna have a look at the manual and tech bullitins but i thought that i would post and see if i got any response ?
IRA 2030 - E003 ERROR
Re: IRA 2030 - E003 ERROR
re-seat the Fixing Unit, or cleaning the Fixing Drawer connector from small pieces of paper has resolved the error code.
If the issue persists, also check the connection of the AC driver connector (to see if the connector is physically removed or disconnected, or the cable is caught).
try checking >re-seating the Fixing Film Connection, perform the error clear: Copier > Function > Clear > Err > and power cycling the machine.
is that the SW 5 (the AC interlock switch ) that had an issue ?**Knowledge is time consuming, exhausting and costly for a trained Tech.**
