Very strange question of IR3035N
  • ts-lx
    • May 2011
    • 59
    [Misc] Very strange question of IR3035N
    Replacement of the fixing unit developing unit drum unit did not solve
    thank you
  • jacky_kuo
    • Aug 2011
    • 54
    Re: Very strange question of IR3035N
    i can tell you ,
    this issue no way to solve ,
    the same machines ,
    some has no this problem ,
    some has ,
    so, installation copyer to need lucky for you....
    our customer ever complain to the same image issue,
    we changed Du, Dev. unit , Fixing unit , DC/Main Con , HVT, adjust service mode.......
    even we swap new machine to customer ,
    new copyer still has the same problem,
    so, time and time again,
    we will tell to ourselves ,
    this issue is not problem, is normal....
    • KL568
      _
      • Feb 2011
      • 324
      Hi,If your machine has practically done what Jacky's method, then it proven beyond all doubts that it the issue with PC printed file. Had you try print another file? Receate a new file with same words to print? Printed the affected file as PDF and see it from Adobe Reader then printed?
      • spectraindo
        • May 2008
        • 313
        Try this : Go to Service Mode LEVEL 2 > COPIER > OPTION > BODY > FIX-SMR = 2 and COPIER > OPTION > BODY > COTDPC-D = 2 Use of compatible Toner also can cause this.
        • montana
          • Aug 2008
          • 392
          Originally posted by ts-lx
          Replacement of the fixing unit developing unit drum unit did not solvethank you
          hi....check the toner quality......
          • zoraldinho
            teacher-guide-expert-guru
            • Mar 2008
            • 5007
            Make a service mode test print (PG). OK test- Change driver NG-Use OEM toner
            • Luther
              • May 2006
              • 682
              I just went thru this and it was non oem toner, cleaned out all toner in dv, sub hopper and used canon oem toner and it cleared right up, you must get all the toner out odf the system
              • Simons
                • Jun 2008
                • 490
                Yes , Generic toner has bigger flakes. Thats the quality of the Canon toner. Smaller Flakes.
                • ts-lx
                  • May 2011
                  • 59
                  Should be solved, the toner is canon. Laser components, the fuser assembly, developing device, the pressure plate, drum unit, fully replaced, not
                  • ts-lx
                    • May 2011
                    • 59
                    Originally posted by jacky_kuo
                    i can tell you ,
                    the same machines ,
                    some has ,
                    Should be solved
                    • Simons
                      • Jun 2008
                      • 490
                      Did you try playing with the dev bias? Also if this is a copy, take off the back cover and remove the reader ribbon coble and reseat/clean. If that is dirty that can cause this problem and other random toner defects in scans/emails etc.
                      • jacky_kuo
                        • Aug 2011
                        • 54
                        你可以不吝告诉我是如何解决的吗
                        • ts-lx
                          • May 2011
                          • 59
                          我没有解决,我都要崩溃了。 打印和复印都一样。
                          • jacky_kuo
                            • Aug 2011
                            • 54
                            ~呵~呵~
                            iRA8105 , iRA6055, iR3570 , iR3245...
                            all has the same issue ,
                            anyway copy or print ......
                            ~唉~
                            • arielcanon
                              • Mar 2012
                              • 106
                              I also found this issue on IR3035, IR3570, IR4570, IR3245. Trying change Fix-Smr = still failed but Luckily I can solve the other (IR3570) by these factor : OEM toner, FIXIng film unit, Pressure and Bearing are smooth
                              Learning never ends..
                              Never give up, where there is a wheel there is a way..
