e246-0002
  • alexctx
    • Dec 2010
    • 157
    e246-0002
    which is code e246-0002 irc5185
  • ADSTech
    • Aug 2012
    • 9
    Re: e246-0002
    E246-002 is related to the ECO-ID board, it is basically saying that the seriel numbers dont match.
    • teckat
      • 16076
      Re: e246-0002
      are u swapping pcb's (:>( ---------------------------------------------------------------------------------------------------------------------------------------------------- DO NOT CHANGE TWO OR MORE BOARDS AT ANY ONE TIME. THIS CAN RESULT IN THE EQUIPMENT ENTERING AN ERROR CODE LOOP. ONCE THIS OCCURS, YOU MUST CONTACT THE CANON TECHNICAL SUPPORT CENTER FOR ASSISTANCE. imageRUNNER C3170U / C3170i / C5870U / C5870i / C6870U / C6870i / Color imageRUNNER C5180 / C5180i / C4580 / C4580i / C4080 / C4080i / C3380 / C3380i / C2880 / C2880i ------------------------------------------------------------------------------------------------------------------------------------------------- The Counter Memory PCB, ECO ID PCB and SRAM PCB retain information pertinent to the specific engine they are installed in. Ensure that you never swap any of these circuit boards with another engine. If any of these circuit boards are swapped, it can result negatively in equipment performance. ------------------------------------------------------------------------------------------------------------------------------------------------ E246-Reinstall original Counter Memory PCB that belongs to that equipment. -Replace Counter Memory PCB with new one.
