IRAC 2030
  • HELIO240
    • Jan 2011
    • 137
    IRAC 2030
    hi , the problem is
    this paper up to the transfer sheet, getting stuck in the ITB cleaning blade smeared in printing. WHAT you guys suggest I do to avoid this problem.
  • teckat
    • 16092
    Re: IRAC 2030
    Originally posted by HELIO240
    hi , the problem is this paper up to the transfer sheet, getting stuck in the ITB cleaning blade smeared in printing. WHAT you guys suggest I do to avoid this problem.
    ---------------------------------------------------------------------------------------------------------------------------------------------------- jam code is > what type of paper ? what is your room enviorment ? what is print % coverage on paper- ---------------------------------------------------------------------------------------------------------------------------------------------------- In service mode; set below to "1"------------------------------------------------------------------------------------------------------------- COPIER>OPTION>IMG-FIX>PRE-CURL=1 (LEVEL 2 SERVICE MODE) COPIER>OPTION>FNC-SW>PRE-CURL = 1 COPIER>OPTION>CUSTOM>FAN-ROT = 1 (LEVEL 2 SERVICE MODE) COPIER>OPTION>FNC-SW>MC-FAN SW = 1
