IR3225N
  • Mina Banoub
    • May 2011
    • 50
    [Electrical] IR3225N
    Hi,
    I have an IR3225 M/C that gives an error code E001 every morning but after clearing the error the M/C works perfect for the rest of the day . In the next day ....Same issue.
    I chnaged the upper fixing film ass`y but still face the same problem.
  • arielcanon
    • Mar 2012
    • 106
    Re: IR3225N
    Originally posted by Mina Banoub
    Hi, I have an IR3225 M/C that gives an error code E001 every morning but after clearing the error the M/C works perfect for the rest of the day . In the next day ....Same issue. I chnaged the upper fixing film ass`y but still face the same problem.
    Check the voltage source for stability, if the voltage source ok, replace the fixing film unit. try another fixing film unit...
    Learning never ends..
    Never give up, where there is a wheel there is a way..
    • Alex ahir
      • May 2012
      • 125
      Re: IR3225N
      what is ther version on the m/c??
      • DAG COPIERS & COMPUTERS
        • Oct 2010
        • 860
        Re: IR3225N
        Ariel is right, start by checking the A.C mains output voltage from the outlet for voltage fluctuations, before venturing into the fixing unit. You may consider using an external voltage stabilizer if need be.
        • Mina Banoub
          • May 2011
          • 50
          Re: IR3225N
          Hi, The A.C mains o/p voltage is ok.And I also tried another fixing ass`y and still have the same problem, Could it be the DC controller ? But, why once a day and only in the beginning of the day when I first turn on the m/c?
          • Rachid.Akli
            • Oct 2011
            • 595
            Re: IR3225N
            Try to verify the custmer socket voltage in the morning. It should be between 200V and 240V.
            Rachid.
            "Find a job you love and you’ll never have to work a day in your life." Nagy's father
