my canon irc3220 machine still warmup
  • arb_shameless
    • Jul 2025
    [Misc] my canon irc3220 machine still warmup
    my canon irc3220 machine still warmup i have canon irc 3220 machine. when turn on my machine it still warmup. what to do any one help me plzzzzzzzz
  • jafari hs
    Re: my canon irc3220 machine still warmup
    check themistors
    • arb_shameless
      i dont understand
      • arb_shameless
        see this image
        • montana
          • Aug 2008
          • 392
          Originally posted by arb_shameless
          see this image
          hi...is there any error codes or messages?................
          • teckat
            • 16083
            A FEW THINGS TO LOOK AT----
            Try to re-seat all the connections and DIMMs on the Main Controller. If re-seating the connections fails to resolve this issue you may have to replace the Memory PCB (FG3-2345-000). The Memory PCB is located on the rear frame behind the Drum Units.
            how old are the DRUMS ///??????????????
            Enter into service mode, display density. One of the toner windows will display -4.75 and the others will display 0. The one at -4.75 has a bad toner add motor and needs to be replaced.
            ++++ Check in service mode, * 2 & 8 *, under Copier > display > Dens. Look at the value for each individual color. The normal value would be between zero and one. If you have a color with a value around four or five you have an issue with the toner/starter concentration level for that color. By replacing that color drum unit you will temporarily resolve the issue due to the Developer Assembly being incorporated with the drum unit, which has the correct toner/starter concentration. To resolve this issue replace the Toner Cartridge Drive Assembly, FG6-8999-000, and the corresponding drum unit at the same time.
