IRADVC5035 Jam code 0207
  • rayjeek
    • Jun 2010
    • 239
    [Jamming] IRADVC5035 Jam code 0207
    I have IRADVC5035 with jam code 0207 flagging PS42 sensor. We fitted a refurbished 3-way unit with all sensors replaced with the white connectors ones. Customer called in today saying it's still jamming. I will have to be suspecting the media in use and the environment. Just wondering if anyone has seen above jam code recurring intermittently. Thanks.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5016
    Re: IRADVC5035 Jam code 0207
    Check inner delivery sensor PS 37.
    Also ispect reverse sensor flag
    Can be a media
    • rayjeek
      • Jun 2010
      • 239
      Thanks. Will check the PS37 tomorrow and let you know. Reverse sensor is however ok.
      • Paul 75
        • Oct 2008
        • 97
        I hads one today with 0207 code. The fuser was over life. Changed film assy . lower roller and lub'd lower bearings and bushes on delivery (orange roller ) job done. Normally get 300k out of film and lower.
        Oh...... I can't copy at the moment then ? !!!!!!
        • rayjeek
          • Jun 2010
          • 239
          Problem solved. Upon checking jam history noted that no 0207 jam code again but 0113. Cleaned vertical path sensor(UN53) but still jamming. Found out later that customer loaded folded paper in between sheets in tray. thanks
