iR7095 Scanning documents analog style
  • dzrtracin
    • Mar 2010
    • 9
    [Misc] iR7095 Scanning documents analog style
    I have a customer that uses a analog NP6551 for a special application. They tape a small paper 1in by 2 1/2in to the glass that has a I.D. code on it, place documents in the feeder & the I.D. tab code gets copied onto every paper. Is there ANY way for a iR7095 to scan an original using the feeder like the NP6551? Anything in the service mode to change? Its a an odd application, but i need this work if possible
  • sx633
    • Sep 2011
    • 49
    Re: iR7095 Scanning documents analog style
    Is this ID tab the same all the time or does it change for different jobs ? I was wondering if you could scan the ID tab in and use it as a "watermark" or "stamp" like you can add "urgent" or "priority" on to copies in the print driver. just a thought.
    • spectraindo
      • May 2008
      • 313
      Yes the IR7095 can do that job. Turn STREAM READING OFF .
      In Service Mode : FEEDER > OPTION > DOC-F-SW = 2 (FIXED READING)
      The Scanning Speed will be slower.
      • dzrtracin
        • Mar 2010
        • 9
        You my friend are the BEST!
        RIDE ON!
        • dzrtracin
          • Mar 2010
          • 9
          It changes 10 times a day, bar code & part numbers, there for nuts, bolts etc. for landing gear. Getting that answer from spectraindo was HUGE. I even called esupport, said it has no chance to do that. I can say, canonesupport is not what it used to be. Thanks again guys!
          • spectraindo
            • May 2008
            • 313
            You're welcome !
