ir2520 e355
  • eurokris
    • 120
    [Error Code] ir2520 e355
    hi all
    after replace new main con came out error code E355
    how to clear this code?
    pls anyone help.
    thanks
  • tieuquyen
    • 33
    Re: ir2520 e355
    Originally posted by eurokris
    hi all after replace new main con came out error code E355how to clear this code?pls anyone help.thanks
    Did you clear code in service mode.This problem happen when the Counter on controller board and counter board not mismatch, or you can re seat the jack on both board. if it not resovle you shoud to replace the counter board too.
    • eurokris
      • 120
      Re: ir2520 e355
      hi sir
      how to clear in service mode?
      • teckat
        • 16083
        Re: ir2520 e355
        hi all
        pls anyone help.
        thanks
        u need to read this/ i have posted this pub a few times on changing/swapping pcb's
        iR B&W Counters_TP05 108d.pdf
        • eurokris
          • 120
          Re: ir2520 e355
          how to clear E355 on ir2520 .dont have E355 clear on service mode.
          please anyone guide me.
          thanks
          • teckat
            • 16083
            Re: ir2520 e355
            thanks
            u need to go in LEVEL 2 of Service Mode----see below
            How to clear the error code:
            1. Enter Service Mode: Press (*) Additional Functions, 2&8 simultaneously, then (*) Additional Functions again.
            2. Then select the [COPIER] option. Under [COPIER], select the Function tab.
            3. Under the [FUNCTION] tab, select the [CLEAR] option.
            4. In [CLEAR] there is a selection E355-CLR. Select it and hit OK.
            5. Reboot the machine.
            * If the error still continues, you probably have a bad Serial Number board and it needs to be replaced.
            if not in Level 2/ may be in Level 3
            • eurokris
              • 120
              Re: ir2520 e355
              IR 2520 enter service mode only showing SSW simillar same ir2016.
              CANT ENTER LEVEL TO 2.
              HAVE ANY OTHER WAY TO CLEAR ON THIS MODEL?
              UNDER CLEAR ASLO DONOT HAVE E355 CLEAR.
              PLEASE ANYONE HELP ME.
              • teckat
                • 16083
                Re: ir2520 e355
                E355 is not used in iR2016/2020
                model does not have a Main Controller PCB. The Counter Memory PCB is instead mounted to the Image Processor PCB.
                did u read the pdf i posted ?????
                In some cases, on the imageRUNNER 1023/ 1023N/ 1023iF/ 2016/ 2020/ 2016i/ 2020i after replacing
                the Counter Memory PCB, an E354 or E355 code may appear.
                At this point, enter service mode then scroll to “CLEAR”. Press “OK”, then scroll to “ERR”. Press “OK”, then an E355 will appear.
                Wait ten (10) seconds until “E355 CLEAR” is completed. Then cycle the main power.
                where is your 2520 manual ?
                • eurokris
                  • 120
                  Re: ir2520 e355
                  i have cant find in service manual
