Cartadis copicode-IP keypad, Papercut and Canon IR ADV c2025
  • sx633
    • Sep 2011
    • 49
    [Electrical] Cartadis copicode-IP keypad, Papercut and Canon IR ADV c2025
    Hi all, I've successfully attached a Cartadis Copicode-IP keypad to an IR Adv C2025 via network cables and it works fine releasing jobs from our customer's "Papercut" system. I have also connected a "serial adapter" (Canon supplied) which runs via a Copicode supplied adapter cable to the copicode keypad. This is plugged in to the mainboard where a Canon control card reader would normally go so I am guessing it needs some settings made within the IR. What we want to do is to disable copying until the user logs in to the management software (papercut), via the copicode keypad, to allow copying. I hope that makes sense. I have tried various settings on the IR related to coin op' or card readers and nothing works, it still allows free reign as far as copying goes. If anyone has experience on either Copicode-Ip keypads and / or Papercut on Canons I would very much appreciate some advice. Thanks.
  • sx633
    • Sep 2011
    • 49
    Re: Cartadis copicode-IP keypad, Papercut and Canon IR ADV c2025
    Thanks for the overwhelming response guys ! Only joking, I know it was a very obscure question. Anyway, if anybody is interested, You need to go into level 2 service mode (*28* - *2) then set Copier > option > Acc > CC-SPSW and set it to 2 (default is 0).
    • teckat
      • 16083
      Originally posted by sx633
      thanks for the overwhelming response guys ! Only joking, i know it was a very obscure question. Anyway, if anybody is interested, you need to go into level 2 service mode (*28* - *2) then set copier > option > acc > cc-spsw and set it to 2 (default is 0).
      [ATTACH=CONFIG]16987[/ATTACH] thanks for the info ~~~~~~~~~~:0)
