canon CLC 3200
  • atech
    • Aug 2010
    • 89
    [Misc] canon CLC 3200
    what causes the scanner of canon CLC 3200 to not to return from home position during a multi-copy from adf?
    During multi-feed after the third or fourth scanning of the original,the scanner get stock at the other end and making noise. I already checked the home position sensor for scanner but no success. However, scanning on the platen has no problem at all.
    need help guys. thanks.
  • teckat
    • 16092
    Re: canon CLC 3200
    This can be caused by a defective Scanner Motor .
    The Scanner Motor looses it's timing from DF and will start to scan the next page in the wrong start position (result is noise).
    First try re-seating the Scanner Motor connections at the Interface PCB.
    or Replace the Scanner Motor ---if re-seating does not work
    • atech
      • Aug 2010
      • 89
      Re: canon CLC 3200
      thank you Sir, I removed the scanner motor and placed it back again and it worked.
      • teckat
        • 16092
        Re: canon CLC 3200
        COLOR HAND.jpg great fix-------------------
