upgrade 512Mb RAM for iR2545
  • tieuquyen
    • 33
    Dear 2 all,
    Can i put laptop RAM to the iR 2545 insteed off using upgrade RAM
  • teckat
    • 16083
    Re: upgrade 512Mb RAM for iR2545
    Originally posted by tieuquyen
    Dear 2 all,
    Standard : 512 MB RAM, Maximum 512 MB RAM
    • KenB
      Geek Extraordinaire
      • Dec 2007
      • 3944
      Even if the RAM were to go bad, you couldn't use laptop RAM, at least in all probability.
      It's different, and not by accident.
      • tieuquyen
        • 33
        thanks for your answer,
        I can use laptop RAM for canon iR 2545.
        and in asia market, canon iR standard include only 256Mb RAM not 512.
        Thanks again.
        • teckat
          • 16083
          Thanks again.
          laptop ram will not work-
          • tieuquyen
            • 33
            It is work perfectly, and which kind off ram did you try. there is alot kind off RAM laptop, and i use success once.
            • teckat
              • 16083
              • swirtycomputer
                [ATTACH=CONFIG]16950[/ATTACH]
                where location to upgrade ram ?
                • Canuck
                  Tech Specialist
                  • 1713
                  Brain dead cheap flash drive machine.....
