ImagePress C1 Batch upload to mailbox
  • gopostal
    Hello, im trying to fill the mailbox with a lot of print files after a 3rth harddisk crash which is a lot of work.
    according to canon there is no such thing as a batch upload or print command.
    is there a solution for this?
    if not, to upload multiple files after each other is not a real big problem if you dont change the filename. and change it afterwards through the remote ui.
    but too bad the "remote ui" does require a lot of clicks to finally be able to change a document name, which is mostly because of an user unfriendly interface.
    which can be altered easily, if it is possible to get access to these files.
    in short , two questions:
    is there a batch upload to the mailbox solution?
    is there a way to edit the intranet "remote ui" scripts/html?
    Thanks in Advance
  • KL568
    _
    • Feb 2011
    • 324
    Re: ImagePress C1 Batch upload to mailbox
    Is machine in question with Fiery or without?
    • gopostal
      Originally posted by KL568
      Hi, Is machine in question with Fiery or without?
      with
      • KL568
        _
        • Feb 2011
        • 324
        For both of your questions, doubtful there is any solution.
        Have you tried, install 1 extra printer driver that is default to Mailbox 1. Then basically print to it. But the headache, would be renaming them when they are in machine's HDD.
        Which Fiery option is attached?
