IR 2520 heater problem
  • mido
    • Nov 2011
    • 177
    Hi,
    I have a prolbem in Canon IR2520, the toner not fixed on the paper it erased when wipe by finger,
    the counter of the machine is about 10.000 copies, the fixing film unit is new and original by canon.
    I want your opinion about this problem
  • tieuquyen
    • 33
    Re: IR 2520 heater problem
    Originally posted by mido
    Hi,
    Did you use OEM toner?
    • mido
      • Nov 2011
      • 177
      I used original toner
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5018
        What tipe of paper do you have? Change paper tipe to heavy and check again.Try with different paper.Can be bad termistor or DC controller.
        Inspect fixing temperature!
        Related Service Mode
        Offset of fixing control temperature (High and low of control temperature)
        PRINT > SW
        > 62 (Control temperature during cassette feeding)
        > 63 (Control temperature in Heavy/Heavy-H/Bond paper modes)
        > 166 (Control temperature for the second side of 2-sided copying)
        > 173 (Control temperature for the second side of 2-sided copying)
        > 179 (Control temperature in Postcard/S-Postcard/Envelope modes)
        <Setting value>
        0 to 2: +15 deg C
        3 to 11: +12 to -15 deg C (each 3 deg C) [Default: 7]
        12 to 14: -15 deg C
        • Rachid.Akli
          • Oct 2011
          • 595
          Hello,
          Have you replaced the film because of E0007 error code or because of the same toner fixing issue that you've now?
          A toner fixing issue may occur because of:
          1- Toner is faulty: It's not your case (you're using canon toner).
          2- The fixing temperature is not high enough. verify it in display mode.
          3- The fixing pressure is not good.
          Good luck.
          Rachid.
          "Find a job you love and you’ll never have to work a day in your life." Nagy's father
          • arielcanon
            • Mar 2012
            • 106
            if u use oem toner, try replacing fixing unit...
            Learning never ends..
            Never give up, where there is a wheel there is a way..
            • good
              • Sep 2012
              • 51
              I have a similar problem before. I just changed my generic toner to a OEM toner.
              Are you sure that you are using OEM Toner?
              • mido
                • Nov 2011
                • 177
                thank you my friend
                yes I am sure using OEM toner,
                • Luther
                  • May 2006
                  • 682
                  Make sure the right door when closed is applying pressure to the fixing unit
