error codes
  • Reeves
    • Apr 2012
    • 296
    [Error Code] error codes
    i have a two canon IR 3300 one with the error code E0001 and the other one E0007 what could be the problem.then i ihave two canon IR 3035 with E0001 and E0007 please advice
  • tieuquyen
    • 33
    Re: error codes
    E0001, E0007 you could be reset its.
    E0007 also 'cos off fixing film problem, is there any scracth on fixing film?
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5015
      Re: error codes
      Error need to be inspected,not just cleared and scracth on the film can't be a reason for E0007.
      • sx633
        • Sep 2011
        • 49
        Re: error codes
        E007 will be a problem detecting rotation of the fixing film. Usually because it is worn or damaged at one end. If it looks ok try cleaning the white square patch on the end. That's what it uses to detect rotation.
        E001 is a temperature detection fault. Replace the heater / film assembly. That usually does the trick.
        • teckat
          • 16083
          Re: error codes
          call for a trained tech/before u stick your head in
