Canon IR2200 "Reached impression limit" message customer can't print or copy
  • axyun
    • Aug 2007
    • 1323
    Customer called with IR2200 . Has message which she dictated to me " Reached impression limit. ecurring job- reserved jobs may be cancelled. Check the print log." It sound to me like customer has to select jobs that are saved to be deleted so that space may be available for future jobs.
    I just get involved with the mechanics of machine. This sounds like a custom or IT problem. Pleas advise so that I can at least inform customer of what to do. Customer has service contract for repairs and is assuming that this is covered and that i should go out there to take care of it. Your input is appreciated very much. Frank/ActionPhotocopy
  • spectraindo
    • May 2008
    • 313
    Re: Canon IR2200 "Reached impression limit" message customer can't print or copy
    If ID mode is set to ON ,set Limits to OFF.
    • axyun
      • Aug 2007
      • 1323
      Do you need ID and password to access system settings and ID mode in order to turn off? Frank
      • teckat
        • 16083
        yes-if Impression Limits were set
        • arielcanon
          • Mar 2012
          • 106
          ask your admin for user & password to access system setting. try use default U/P = 7654321 or you can clear password via service mode if you forgot the password
          Learning never ends..
          Never give up, where there is a wheel there is a way..
          • axyun
            • Aug 2007
            • 1323
            Thanks for this useful information. Customer will be back Monday and I will follow up then. Frank
            • axyun
              • Aug 2007
              • 1323
              Thanks again to all for your help. I spoke with customer on phone yesterday and guided her thru procedure to set limits to off. Frank
              • spectraindo
                • May 2008
                • 313
                You're wellcome
