canon ir5065 error 423-002
  • smiley
    • Aug 2008
    • 615
    hi guys good day. i dont know what this error is can any body help me on this please.
    there is no glory without sacrifice
  • teckat
    • 16083
    Re: canon ir5065 error 423-002
    E423--0002
    Error in SDRAM (video image memory) verify in reader-
    try re-seating the DIMM on the Memory Controller pcb
    • tenatal
      • Aug 2011
      • 35
      u may try this - (not sure)
      disconnect adf from machine and then check for any errors
      (the error may be caused by adf misfunctioning)
      • smiley
        • Aug 2008
        • 615
        thanks for the reply guys. i try to remove the dadf and boot up the machine there are no any error appear then i figure out that the error is on dadf i clean the and reset all connectors on dadf and reassemble the dadf and put the connector back then machine are on normal condition again. thanks again guys these machine has a single pass dadf.
        • teckat
          • 16083
          Loose Connectors
          • dell
            1. When a faulty image ascribed to CIS scanning side occurs at two-sided simultaneous scanning, re-fit J308 connector on the interface PCB, and then make copies.
            2. Suspect poor connection of the DIMM mounted on the backside of the memory PCB (FM3-4436-000) found in the reader unit. Remove the DIMM, clean its terminal with lint-free paper moistened with alcohol, re-fit the DIMM, and then make copies again.
            • teckat
              • 16083
              poster fixed issue already
