Canon ir 3300 537-0000 error
  • edwin
    • Jan 2012
    • 28
    I have receiving 537-0000 error in my canon ir 3300 machine. Any suggestion to solve this issue?
  • Canon.Tech
    • Mar 2009
    • 335
    Re: Canon ir 3300 537-0000 error
    You have an fault with your finisher.
    The front alignment motor (M3) is faulty.The front aligning plate home position sensor (S6) is faulty.The front alignment motor relay harness is faulty.The front aligning plate is subjected to an excess load.The aligning plate home position sensor (S6) does not go ON when thefront alignment motor (M3) is driven for a specific number of rotations.The aligning plate home position sensor (S6) does not go OFF when the
    • edwin
      • Jan 2012
      • 28
      thanks for your reply. is there any solution to solve this?
      • Canon.Tech
        • Mar 2009
        • 335
        Move the front alignment arm by hand, check it moves ok, it could be obstructed by staples, paper clips, small jammed paper etc.
