Dirty copies after replacing stirrer motor
  • rbrendemihl
    • Oct 2009
    • 15
    [Misc] Dirty copies after replacing stirrer motor
    Canon iR5570, started with a stirrer motor error E025, replaced the motor and the copies were toned, black on the bottom. E061-002 Cycled stir toner, replaced the potential sensor unit, the laser scanner unit and the board and it is still doing it.
    Any ideas?
  • teckat
    • 16083
    Re: Dirty copies after replacing stirrer motor
    laser shutter position inspect Laser Shutter Links in the Laser Scanner Mount Assembly (deformed / bent)-
    what pre-conditioning lamp -all light ?
    --To check the pre-conditioning lamps, the front door switch has to be cheated and the primary corona removed after the machine is in a ready state.
    Perform the following to light the Pre Condition Lamps:
    Copier > Function > Misc-P > PRE-EXP
    bottom side ? u mean operator side ? or non-operator side ?
    • canonbundy
      • Jun 2012
      • 607
      How many prints has Primary Charge Unit done - maybe check for wire break/replace unit.
