iR4570 Need Comments on Spooling Issue
  • goldencup
    • Nov 2008
    • 366
    [Misc] iR4570 Need Comments on Spooling Issue
    Hi, i would like to hear from you guys if you have some spooling issue on iR4570. Has anyone of you encountered very slow printing on this unit. What is the performance of this machine when used on the following: (mostly if the file is too large)
    WORD
    PDF
    AutoCAD
    Thank you very much.
  • tenatal
    • Aug 2011
    • 35
    Re: iR4570 Need Comments on Spooling Issue
    which driver are u using, there is lot of difference in speed in varying driver and software u r using for printing pdf, word or autocad files.
    also can set - spooling on/off on the machine by going in system settings > network settings > use spooler > on/off.
    also can set - printer settings > print after complete rip > on/off.
    • goldencup
      • Nov 2008
      • 366
      Hi, Thank you for the reply. I'm using UFR II Driver
