Canon IR6020i with F1 finisher and 1135 jam code
  • Desert Rat
    • May 2008
    • 1089
    I ran about 60 pages before this happened. While doing a "P" print the rear guide came over and pinched
    the paper and it would not exit.
    The jam code sez it did not exit the stapler tray after a motor came on if that is any help.
    I will read through the book tonight looking for clues, if anyone has a suggestion I would
    be happy to hear or read it.
    DR
  • teckat
    • 16092
    Re: Canon IR6020i with F1 finisher and 1135 jam code
    Escape solenoid==SL6
    • CaptnRed
      • Apr 2011
      • 62
      Teckat is right, solenoid 6 is most likely faulty, had handful of them go bad. See the four attachments below.
      CTSB 1135 Jam code displayed.pdf
      CTSB 1135 Jam Code.pdf
      CTSB 1135.pdf
      CTSB Finisher Jams of 1134 and 1135 are Occurring.pdf
      • Desert Rat
        • May 2008
        • 1089
        Thanks for the rapid reply.
        I will download this info and check it out.
        Thanks again
        DR
        • Desert Rat
          • May 2008
          • 1089
          Problem solved: The front guide was sticky due to the foam pad under the stapler tray. Pushing easy on the
          the front guide I could feel it stick.
          I removed the lower grate and was able to get a screw driver blade under the stapler tray to scrap
          the old foam pad off. I got some toner on a swab and dabbed it on the glue that was left to prevent
          the guide from sticking on the left over glue.
          Hope this helps someone else
          DR
          • teckat
            • 16092
            DR
            good fix/
            reminded me that "I HATE ALL CANON FOAM PADS" especially on Sorters/Finishers
            • Desert Rat
              • May 2008
              • 1089
              I can't help but wonder how many more foam pads
              are in the finisher?
              DR
