iR4570 regarding Boot ROM replacement
  • goldencup
    • Nov 2008
    • 366
    I have an IR4570 machine only without printer (C Boot ROM), and a non working machine but with printer (N Boot ROM), can i get the N Boot ROM of the non working machine and place it to the good machine so that i will function as printer? Do i also need to replace the hard disk?
    Or is this the same as scanner kit that you cannot just replace it to another unit because of the license?
    If it is okay to replace, any adjustment or settings to be made?
    Thank you very much.
  • Brian8506
    • 1665
    Re: iR4570 regarding Boot ROM replacement
    You can just switch the boot rom
    • blazebusiness
      SanDiegoCopierRepair.com
      • 1257
      No license issues--Just switch the bootrom and you will have the printer option & you may need to load system software. Replacing the hard drive is not necessary.
      • goldencup
        • Nov 2008
        • 366
        Thanks for your reply guys
        • Peter Sim
          • Sep 2008
          • 445
          Yes you can but you need to add another 256 ram to make it machine work as printer.
          • goldencup
            • Nov 2008
            • 366
            Thank you for that advise, is that the reason why i get the code E000744-3020? I already replace the Boot ROM but this error appears, i also tried an H Boot ROM still the same error.
            • Peter Sim
              • Sep 2008
              • 445
              Yes, you need a total 512 ram for H and N boot rom
              • goldencup
                • Nov 2008
                • 366
                Thank you very much, problem solved
