iR4570 8.5x13 size is not detected
  • goldencup
    • Nov 2008
    • 366
    Hi, how do you configure the iR4570 so that when i print a file from a computer with the size of 8.5x13 it will automatically detect the tray and print. What happens now is that when i try to print the file, the machine beeps and it says load paper and the size that is indicated is FREE.
    By the way my paper tray settings are FOLIO and LEGAL but neither one of the tray is detected. Any adjustments for this? Thank you very much.
  • vigour
    • Aug 2010
    • 1038
    Re: iR4570 8.5x13 size is not detected
    AS far as I know, automatic output only works with standard sizes.
    There is paper size override in the printer settings , but I think that only works when printing metric standard sizes unto US standard sizes.
    • goldencup
      • Nov 2008
      • 366
      Thanks for the reply. I'll check on that. Also i'll try FLSC.
      • goldencup
        • Nov 2008
        • 366
        It did work on FLSC
        • vigour
          • Aug 2010
          • 1038
          Ok
          I guess because foolscap is a standard size.
          google says 8.5 x 13.5
          Folio paper is 8.27 x 13 inches (= 210 x 330 mm).
          That is the modern size, defined in metric units.
          Books are sometimes described as being folio, referring to the size of each page. The traditional size, defined in imperial units, was 81/2 x 131/2 inches (216 x 343 mm ). An alternate name, foolscap, referred to the traditional watermark design, depicting a medieval fool's cap.
          • teckat
            • 16083
            US Misc. mm X mm Inch X Inch
            Folio 215.9X330.2 8.5X13
            Quarto 215X275 8.46X10.8
            Tabloid 279.4X431.8 11X17
            Ledger 279.4X431.8 11X17
            Foolscap 342.9X431.8 13.5X17
