light copy in IR 1600
  • mido
    • Nov 2011
    • 177
    Hi everybody,
    i have a problem in IR 1600, light copy,
    I replaced the drum unit original one and new toner but same same light copy,
    the counter of the machine about 30.000 copies
    thanks
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5018
    Re: light copy in IR 1600
    Replace the developer ciylinder blade.Use the new type of Blade. FB6-2022-020
    extend the length [A] of the Blade [1] by 1 mm so that the contact surface with the Developing Cylinder [2] is enlarged; thus the amount of Toner coating increases.
    • Mina Banoub
      • May 2011
      • 50
      Originally posted by mido
      Hi everybody,
      thanks
      Hi Mido,
      first, wipe the developing cylinder with a suitable solvent and make sure to dry it out well.
      second, carefully clean the laser unit .
      • mido
        • Nov 2011
        • 177
        Originally posted by Mina Banoub
        Hi Mido,
        Hi Mina,
        thank you very much for you reply,
        I wiped and cleaned the cylinder and the laser unit and replaced the toner powder but same same,
        regards
