Overvoltage on IRC2620
  • Rachid.Akli
    • Oct 2011
    • 595
    [Electrical] Overvoltage on IRC2620
    Hello to all of you
    We recently have an IRC2620 on which an external overvoltage took place. The machine doesn't switch on and the green led is off. We replaced the "all day power supply", the green led is lighting but the machine doesn't start (no rotation) and the LCD is black. I noticed that the documentation is confusing me. There are many power supply PCBS and i just ignore where to start. Thanks for any help.
    Rachid.
    "Find a job you love and you’ll never have to work a day in your life." Nagy's father
  • mramlawi
    • Jul 2011
    • 838
    Re: Overvoltage on IRC2620
    Originally posted by Rachid.Akli
    Hello to all of you
    Rachid.
    Dear Rashind
    this problem occurs with me always replace the Power Supply all of it (its a rectangle unit) .if this didnt works try to change the MFC Boards (this included the Boot ROM ,RAM ,HDD) 100 percent it will work .
    regards
    Distinguished road makes you jewel in rough
    • teckat
      • 16083
      Hello to all of you
      Rachid.
      Printer Leakage Breaker -by power switch ----checked
      check for AC into on printer plug side to AC out past breaker ?
      If the protective function has gone ON, turn off the power switch of the printer unit, disconnect the power plug of the printer unit or the accessories power supply circuit, and remove the cause of activation; then, leave the machine alone for about 3 min, and turn it on to reset.
      • Rachid.Akli
        • Oct 2011
        • 595
        Dear all,
        The "all day power supply PCB" we replaced was defective. We ordered another one which solved the issue. The part number is : FK2-0111-000.
        Rachid.
        • SCREWTAPE
          East Coast Imaging
          • 3396
          Dear all,
          Rachid.
          Nice!
