Jam 0B00 on iRC 2380 when duplexing.
  • Ingranaggio_rotto
    • Oct 2010
    • 275
    Here I am after so long!
    I display this problem: iRC 2380 when he made copies or prints double-sided paper jam code 0B00 ....
    The problem is intermittent ......
    Can you help?
    Thank you all!
  • Rachid.Akli
    • Oct 2011
    • 595
    Re: Jam 0B00 on iRC 2380 when duplexing.
    Hello,
    0B00 is a door open jam. During printing, the machine has detected that one of its doors is open.
    In I/O verify the state of the door open/close sensors when the jam is declared:
    Address P007
    Bit11 Pickup (lower right) door open sensor signal 1: Closed
    Bit12 Front door open signal 1: Closed
    Bit13 Feeder (right) door open sensor signal 1: Closed
    Good luck.
    Rachid.
    "Find a job you love and you’ll never have to work a day in your life." Nagy's father
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5018
      Door swich or reg.roller grounding plate.
      • Ingranaggio_rotto
        • Oct 2010
        • 275
        Thanks for these tips ....
        I will check!
