E013 on iR 6570
  • Ingranaggio_rotto
    • Oct 2010
    • 275
    E013 on iR 6570
    Another problem: error code E013 on iR 6570 ...
    I unlocked the screw which transports the waste toner recovery bottle.
    But once the group reassembled the machine keeps giving me an error code ...
    I also reset the counter on the toner ..... But nothing .....
    Suggestions?
    Thank you!
  • teckat
    • 16083
    Re: E013 on iR 6570
    Suggestions?
    Thank you!
    check the MSW5 switch
    J107B DC PCB ?
    • Rachid.Akli
      • Oct 2011
      • 595
      Re: E013 on iR 6570
      Hi,
      Verify the state of the waste toner feedscrew switch signal SW5 in :
      service mode> I/O > P002 > bit 15 > 0: lock.
      Rachid.
      "Find a job you love and you’ll never have to work a day in your life." Nagy's father
      • Ingranaggio_rotto
        • Oct 2010
        • 275
        Re: E013 on iR 6570
        Ok ..... I will follow your instructions!
        • MFPTech
          • 486
          Re: E013 on iR 6570
          Originally posted by Rachid.Akli
          Hi,
          Rachid.
          How do you fix the problem please if after empting the waste toner bottle, inspecting the waste toner drive and waste toner feed-screw switch, clearing the counter, and trying to clear the error under Function, E013-0001 it's still there?
          Thanks in advance!
