E020-01a9 on imagePress C1
  • Ingranaggio_rotto
    • Oct 2010
    • 275
    And still another ............
    iP-C1: error code E020-01a9: After several checks I found that the yellow toner is not transported in developing unit and crowded under the hopper of the color ...
    By manually rotating the screw transport toner, runs properly ....
    I cleaned up the area using the suction toner, but I did not get any results .....
    The hopper works regularly .....
    Has it ever happened?
    Hello .......
  • teckat
    • 16083
    Re: E020-01a9 on imagePress C1
    Hello .......
    Troubleshooting Procedure for E020 Error Codes-iPRC1 E020 .pdf
    The ATR Shutter can be dislodged when installing and removing the Developer Assemblies from the Rotary Unit. E020-01A9 can be displayed when the ATR Shutter becomes dislodged
    also read-----E020 Error Code Workflow-imagePressC1.pdf
    • Ingranaggio_rotto
      • Oct 2010
      • 275
      Thanks for the pdf document ... I will consult with great interest!
      Now: The ATR sensor should work, as the error code only appears every 8-10 prints ...
      Unless a, there is some value out of range that brings the machine to continuously feed toner yellow ....
      Great idea! !
