IR 2200i horizontal lines on print (especially at start of page)
  • CWright
    • Sep 2012
    • 8
    Hello Everyone,
    Our canon ir 2200i is printing black horizontal lines on printouts and copies as seen on the attached picture "blank_page". I think the culprit might be the development unit or the photosensitive drum.
    When I check the developing cylinder (the drum you see when you pull out the developing unit, where the toner sits on. Check attached picture "dev_asm_ton") I can see that the drum is not fully covered in toner (see attached picture "dev_asm_drm"). Is this the cause? Why is the top of the printed page affected more than the rest of the print?
    I think the problem started after a paper jam.
    Any I ideas on the cause and steps to correct this problem would be much appreciated.
    Kind regards
    CWright
  • roller
    • 26
    Re: IR 2200i horizontal lines on print (especially at start of page)
    Replace the drum unit.
    • CWright
      • Sep 2012
      • 8
      Do you mean the photosensitive drum (not shown in picture) or the drum of the development unit (shown in pictures)?
      Kind regards
      CWright
      • roller
        • 26
        Kind regards
        CWright
        Photosensitive
        • mramlawi
          • Jul 2011
          • 838
          Blindly change the DRUM
          Distinguished road makes you jewel in rough
          • CWright
            • Sep 2012
            • 8
            When I checked the photosensitive drum I could not see any visible damage on the part of the drum that I could see.
            CWright
            • zoraldinho
              teacher-guide-expert-guru
              • Mar 2008
              • 5018
              photosensitive drum
              • CWright
                • Sep 2012
                • 8
                When I make a COPIER>TEST>PG Type6 print I get a print with noticable dense black "lines". See attached picture "PG_Type6".
                CWright
                • CWright
                  • Sep 2012
                  • 8
                  Originally posted by zoraldinho
                  photosensitive drum
                  What makes everyone so sure it's the photosensitive drum? Just curious
                  And I also hope that it's the photosensitive drum, getting a new development assembly (roller + cleaning blade) will be much more difficult for me.
                  CWright
                  • certifiedxeroxtech
                    • Nov 2009
                    • 27
                    dont freak yourself change the drum. It is grounded. clean also the development cylinder and adjust the doctor blade.
                    "prepare your contingency plan as always"
                    • zoraldinho
                      • Mar 2008
                      • 5018
                      To good lines for developer or drum issue.It s some kind of roller trail.
                      • CWright
                        • Sep 2012
                        • 8
                        Oddly enought when I compare the two prints (blank page, PG_Type6) I can see that the black lines that turn up on the blank page, turn up as white lines on the PG_Type6 print. As for where those black fuzzy lines on the PG_Type6 print come from... I have no idea.
                        CWright
                        • zoraldinho
                          • Mar 2008
                          • 5018
                          Yes.It s drum issue.Replace it and don't worry.
                          • CWright
                            • Sep 2012
                            • 8
                            OK, I am ordering a new photosensitiv drum as this has been unanimously stated as the solution. I will let you know if the fault has been corrected as soon as I have installed the new drum.
                            • ericang
                              • Dec 2010
                              • 39
                              certified..... could be right....
                              your PG type6 print shown total 6 similar line which is come from the faulty with your developing cylinder...
                              this might also by bad toner quality
                              drum damages show repeated marking 3 time..
                              primary charger n transfer chargers show more than 6 time...
