IRC4080 colos problem
  • msmy
    • May 2010
    • 123
    [Misc] IRC4080 colos problem
    Hi,
    I have problem to calibrate color on IRC4080i. Attached are the PG6 and PG10.
    calibration.pdf
    PG10.pdf
    PG6.pdf
    Please help me to solve this problem.
    thankx.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5005
    Re: IRC4080 colos problem
    What are you done so far?
    Try with Service mode 2: Function/Laser: LD-ADJ-Y, LD-ADJ-M, LD-ADJ-C. Enable with OK
    These operations allow the Y,M,C Lens to be reset to the middle position via the Service Mode.
    • pontiac
      • 420
      Ck your laser settings with the factory print out in front door, and correct in service mode 1 laser adjustments, also i have had this issues with the transfer belt assembly being worn out and dirty.
      • teckat
        • 16083
        Originally posted by msmy
        Hi,
        [ATTACH]17079[/ATTACH]
        [ATTACH]17080[/ATTACH]
        [ATTACH]17081[/ATTACH]
        thankx.
        First----your ITB unit needs maintenance (clean & or replace belt, when belt is removed> clean the black rubber roller)
        see pub posted by a fellow poster in this forum>>>>
