ImagePress Server Q1
  • manuelubau
    • Aug 2011
    • 62
    I just got an Used Server Q1... I was able to connect it to the machine and my computer and the computer detects the ImagrePress C1... Everything seems normal when I install the copier and the driver that I downloaded from Canon. But when I print a test page nothing happens... I was able to print the Server's Configuration Page from copier... but I am still not able to print from Computer... It seems like the computer sends the print to the Server but the server doesn't transmit the page to the Copier... I need help. Do you think that the driver is wrong? do I need to install something special for the Server Q1? I have windows 7 64bit.
    Thanks a lot!
  • manuelubau
    • Aug 2011
    • 62
    Re: ImagePress Server Q1
    I got it to print... What I did was that I reinstalled the printer using the Server's Q1 driver instead of the ImagePress C1's Driver... But now the quality is bad... is that the correct the driver?
    • teckat
      • 16092
      imagePress Q1 = no driver support for win7 32 or 64bit
      imagePRESS Server Q2 v2.0 is supported/
      Upgrading from imagePRESS Server Q1 to imagePRESS Server Q2
      By installing the imagePRESS Server Q2 V2 system software, the imagePRESS Server Q1 Ver.1.1
      can be upgraded to imagePRESS Server Q2 V2. This is a software upgrade only.
      The software and printer differences are displayed as shown below in the Configuration Page
      imagePRESS Server Q1 Ver.1.x: EFI Fiery System 8
      imagePRESS Server Q2 V2: EFI Fiery System 8 Release 2
      imagePRESS Server Q1 Ver.1.x: Canon imagePRESS Server Q1
      imagePRESS Server Q2 V2: Canon imagePRESS Server Q2-2
      When upgrading from imagePRESS Server Q1 to imagePRESS Server Q2 V2, it is also required to upgrade
      the engine to the latest firmware version available.
      imagePRESS C1 (CUFxxxxx)SER#
      imagePRESS C1 (Version 51.01 & later) needed to support an upgrade to Q2
      call a Canon Authorized dealer to have a tech do the upgrade-----
      • KL568
        _
        • Feb 2011
        • 324
        Teckat's suggestion is good as it would open a few features within that Q1 hardware, but i assume charges would be applicable
        Else you could tried this link without the upgrade but might not be 100% suitable for your printing colour needs
        • manuelubau
          • Aug 2011
          • 62
          Originally posted by teckat
          imagePress Q1 = no driver support for win7 32 or 64bitimagePRESS Server Q2 v2.0 is supported/ Upgrading from imagePRESS Server Q1 to imagePRESS Server Q2By installing the imagePRESS Server Q2 V2 system software, the imagePRESS Server Q1 Ver.1.1can be upgraded to imagePRESS Server Q2 V2. This is a software upgrade only.The software and printer differences are displayed as shown below in the Configuration PageimagePRESS Server Q1 Ver.1.x: EFI Fiery System 8imagePRESS Server Q2 V2: EFI Fiery System 8 Release 2imagePRESS Server Q1 Ver.1.x: Canon imagePRESS Server Q1imagePRESS Server Q2 V2: Canon imagePRESS Server Q2-2When upgrading from imagePRESS Server Q1 to imagePRESS Server Q2 V2, it is also required to upgradethe engine to the latest firmware version available.imagePRESS C1 (CUFxxxxx)SER#imagePRESS C1 (Version 51.01 & later) needed to support an upgrade to Q2call a Canon Authorized dealer to have a tech do the upgrade-----
          The thing is that I am in Nicaragua... there is no canon support here for this kind of equipment... and if there was it would be way too expensive... is there a way I could do the upgrade myself?
          • teckat
            • 16092
            upgrade is possible if C1 printer meets posted requirements -
            another useful PDF on updates after u install Q2>
            • its_just_a_copier
              • May 2011
              • 132
              As far as the poor quality goes you should Calibrate the server....
              • teckat
                • 16092
                imagePress Q1 = no driver is available for posters win7 32 or 64bit/
                don't know what poster is using for their win7 64bit ??
                • manuelubau
                  • Aug 2011
                  • 62
                  File Name:Q1v1.1_PS_Vista_Print.exe
                  imagePRESS Server v1.1 Postscript Printer Driver v1.1 for Windows Vista 32-bit and 64-bit OS (Non-WHQL Certified). This driver adds support for Windows Vista 32-bit OS and Windows Vista 64-bit OS.
                  That is the description of the file that I am using.... I downloaded it from the canon web page.... it seems to work fine... but I will try to upgrade it to Q2... today I printed some pictures for a customer and it was fine since I tried doing the calibration as someone said above...
