PRINT QUALITY
  • anand8620
    • Jul 2012
    • 34
    PRINT QUALITY
    Hi
    Recently I have used <CCD-Adj, White-me,Pd Dens,PD-me>. Now the content is not getting darker when I increase the dark level. Here temp 30C and Hum 47.
    Can anyone guide me to adjust the laser or something else to over come this problem.
    ANAND
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5013
    Re: PRINT QUALITY
    Model?
    • anand8620
      • Jul 2012
      • 34
      Re: PRINT QUALITY
      Originally posted by zoraldinho
      Model?
      CANNON IR3300
      • zoraldinho
        • Mar 2008
        • 5013
        Re: PRINT QUALITY
        Do you have OEM drum and toner?Light copies and prints?
        • certifiedxeroxtech
          • Nov 2009
          • 27
          Re: PRINT QUALITY
          check the toner save mode.
          "prepare your contingency plan as always"
          • anand8620
            • Jul 2012
            • 34
            Re: PRINT QUALITY
            Yes. I have checked OEM drum and Toner. Both are sustain. I have cleaned the scan glass.Mirrors and lens inside the scaner bed. ANAND
            How can I set toner save mode
            • Canon.Tech
              • Mar 2009
              • 335
              Re: PRINT QUALITY
              You can adjust DENS or DEVELOP to darken or lighten the prints or copies
              COIPER>ADJUST>DEVELOP
              There is no toner save option on this model.
              • anand8620
                • Jul 2012
                • 34
                Re: PRINT QUALITY
                Thank you, Please guide me in setting the values. Here I am seeing
                DE-DC 24 (0-255)
                DE-OFST 128 (0-255)
                Please help me in this.
                ANAND
                • Canon.Tech
                  • Mar 2009
                  • 335
                  Re: PRINT QUALITY
                  Hi, I use the DE-OFST a higher number lightens the prints, lower darkens 128 is default.
                  • ericang
                    • Dec 2010
                    • 39
                    Re: PRINT QUALITY
                    Hi
                    ANAND
                    It is not recommended to alter the value in the DEVELOP section in service mode...
                    you might get e064 if your value is too low or high....
                    hav you try to replace drum unit, toner tank, n transfer roller?
                    these are the main cause for faulty output..
                    is this happen in copy mode n print mode?
                    if only print mode... go the Printer Setting n turn off Toner Save option..
                    by the way.. do u hav the correct procedure to used ccd-adj,white me, pd-dens, pd-me
                    • anand8620
                      • Jul 2012
                      • 34
                      Re: PRINT QUALITY
                      It is in copy mode and that to normally it is good. The problem is whenever I use to dark the content for poor copy only. I have done ccd-adj,white me, pd-dens, pd-me as I have been advised in my previous thread. I placed 10 white sheets on copy board press the CCD operation until it is ok. Then i replaced with another 10 white sheets and start the white me, After that I started PD dense without removing 10 sheets I placed the test paper obtained in Pd dense as per the instruction vertically and turn the PD Me until it showed me ok. I have checked OEM drum fuse assembly. Finally my problem is how to get good quality if the original copy is in poor copy. QUOTE=ericang;309845]It is not recommended to alter the value in the DEVELOP section in service mode... you might get e064 if your value is too low or high.... hav you try to replace drum unit, toner tank, n transfer roller? these are the main cause for faulty output.. is this happen in copy mode n print mode? if only print mode... go the Printer Setting n turn off Toner Save option.. by the way.. do u hav the correct procedure to used ccd-adj,white me, pd-dens, pd-me[/QUOTE]
                      • anand8620
                        • Jul 2012
                        • 34
                        Re: PRINT QUALITY
                        [/QUOTE]
                        please guide me in this.
                        ANAND
                        • anand8620
                          • Jul 2012
                          • 34
                          Re: PRINT QUALITY
                          DE-DC 24 (0-255)
                          DE-OFST 128 (0-255)
                          ANAND
                          t is in copy mode and that to normally it is good. The problem is whenever I use to dark the content for poor copy only. I have done ccd-adj,white me, pd-dens, pd-me as I have been advised in my previous thread. I placed 10 white sheets on copy board press the CCD operation until it is ok. Then i replaced with another 10 white sheets and start the white me, After that I started PD dense without removing 10 sheets I placed the test paper obtained in Pd dense as per the instruction vertically and turn the PD Me until it showed me ok. I have checked OEM drum fuse assembly. Finally my problem is how to get good quality if the original copy is in poor copy. QUOTE=ericang;309845]It is not recommended to alter the value in the DEVELOP section in service mode... you might get e064 if your value is too low or high.... hav you try to replace drum unit, toner tank, n transfer roller? these are the main cause for faulty output.. is this happen in copy mode n print mode? if only print mode... go the Printer Setting n turn off Toner Save option.. by the way.. do u hav the correct procedure to used ccd-adj,white me, pd-dens, pd-me [/QUOTE]
                          • teckat
                            • 16083
                            Re: PRINT QUALITY
                            if the original is poor>
                            there is little you can do to get a good copy>
                            when you try to darken a poor original copy on glass> you will usually have dark background the printed copy/
                            the light to dark adjustment on control panels is a waste of time
                            a good original will result in a good copy if all is ok with printer
                            your best bet is to get a MANUAL to study
                            • teckat
                              • 16083
                              Re: PRINT QUALITY
                              CANNON IR3300
                              you said you have a iR3300 >
                              what type of documents are you putting on the glass to copy ???
                              are they COLOR documents or plain B & W documents ??
