Canon ir c5185 losing laser settings
  • pontiac
    • 420
    We have 5185 that loses it's laser settings about every three days. The copier is left on 24/7, options include fax, print and scan. I re-enter the laser settings , perform gradation and copy quality is restored. Any thoughts on what keeps causing this?. Thanks
  • vigour
    • Aug 2010
    • 1038
    Re: Canon ir c5185 losing laser settings
    give us an example of the random laser settings.
    Are they much higher or lower than they should be?
    • pontiac
      • 420
      pve-ofst setting may start off -12 but changes it's setting to 0 all laser settings change to 0 and i have to re-enter all of them.
      • vigour
        • Aug 2010
        • 1038
        only thing i can think of is a dead or dying backup battery, possibly on main controller or laser driver
        change your service mode to *49* to eliminate someone messing with it.
        • teckat
          • 16083
          service manual had an error in posting label/ correction was released 2007
          make sure your individual Y/M/C/BK laser settings are entered from the values shown on the label
          affixed on the laser unit-
          CLICK ON PIC BETTER VIEW
          Laser Manufacturer ID:
          [1]COPIER > ADJUST > LASER > LA-MK-Y/M/C/K
          Laser Magnification:
          [2]COPIER > ADJUST > LASER > LDADJ1-Y/M/C/K
          [3]COPIER > ADJUST > LASER > LDADJ2-Y/M/C/K
          [4]COPIER > ADJUST > LASER > LDADJ3-Y/M/C/K
          Laser Phase Difference:
          [5]COPIER > ADJUST > LASER > LDADJ4-Y/M/C/K
          [6]COPIER > ADJUST > LASER > LDADJ5-Y/M/C/K
          [7]COPIER > ADJUST > LASER > LDADJ6-Y/M/C/K
          • Fer
            • Nov 2009
            • 267
            • pontiac
              • 420
              Thanks everyone for replys. I set each laser cam at home position first then i entered the values from each lasers label.I also rebuilt another transfer belt assembly and installed it just to eliminate any belt issues since this call is 120 miles away i did not want to chance it. Did adustments on monday i will post results in the next few days. Thanks again.
              • teckat
                • 16083
                PVE-OFST/ this number should be entered from your original service print/
                did u run FULL AUTO-GRADATION -after entering laser label numbers-
                Did u check the ITB Reference Patches/& Correction Patterns- on power up ???
                what did your images/issue look like before settings change (CQ,PRINTER ERRORS ??)
