Canon ir4570 E-000064-003 code
  • jmart77
    • Mar 2006
    • 71
    This code pops up once in awhile the copier also makes blank copies. Does anybody Know what this code and sub-code is I don't have a manual for this machine thanks!
  • _SuabE_
    • Jan 2008
    • 108
    E064 The voltage of power supply is faulty (high-voltage error)
    003 - While the output is being generated, the AD value of the developing DC voltage is 224 (DEC) or more
    -- Replace the high voltage power supply. FM2-0261
    sigpic
    Senior Technician Specialist
    A+; Network+
    Copier Brand handled: Canon, Lanier, Konica Minolta, Sharp, Ricoh, Kyocera Mita, Nashuatech, Ollivetti, Toshiba
    Printer Handled: Canon, HP, Epson, Brother, Samsung
    Duplicators: Risograph, Duplo
    • jmart77
      • Mar 2006
      • 71
      I'll try replacing FM2-0261 I'll let you Know what happens. Thanks!
      • jmart77
        • Mar 2006
        • 71
        I couldn't find FMZ-0261 High Voltage power supply in this machine. Could any body give me another idea on which one it is thanks
        • _SuabE_
          • Jan 2008
          • 108
          Please check your email jmart i did sent to you the pictorial view of the location.
          sigpic
          A+; Network+
          • junkiemanxl
            • Dec 2007
            • 49
            I'm having the E064 code as well on an IR3320i. It crashes the HDD after that error code and E602 will appear shortly. Does that apply to the ir3320i model as well?
