uneven density in sub scan direction problem.IR 6000
  • selmila
    • Aug 2012
    • 133
    i am facing uneven density in sub scan direction problem in IR 6000 an i have checked most of the parts and it looks like the problem is solved but it comes back after few prints. can i get help on this problem.
  • teckat
    • 16083
    Re: uneven density in sub scan direction problem.IR 6000
    is this issue from > Glass Copies / DF copies / Network Prints / Duplex / MF tray /
    from all paper feed locations ?? paper type ?
    Did u follow this procedure iR6000 Shifting Registration
    Clean bushings and both registration roller shafts with alcohol. Do not lubricate.
    Lubrication of plastic bushings attract dust and dirt, only brass bushings should be lubricated unless otherwise stated in service manual.
    Inspect Registration roller for flat spots on rubber roller.
    Replace Registration Clutch
    Inspection of the Pre-Registration Drive Assembly -check bearings-Idler Shaft they are on may also be worn--
    A One Inch From The Lead Edge, When Utilizing the Decks or Cassettes and Two Inches from the Bypass Tray.replace the Registration/Transfer Assembly
    see pics below---- paper feed = (SUB SCAN)
    first pic 1" example =Utilizing the Decks or Cassettes
    second pic 2" example=Bypass Tray
