what is cubic board on ir105 PCB !?
  • oommiiddaann
    • Feb 2012
    • 34
    what is cubic kit on ir 105 PCB !? and how does it work !?
  • teckat
    • 16083
    Re: what is cubic board on ir105 PCB !?
    Why
    (relay)
    • oommiiddaann
      • Feb 2012
      • 34
      i have a ir105 and i open main pcb box from the back of machine and on the pcb board i see a riser board and a cubic board on pcb.the machine work normaly without this.riser board uses for add device on main controller pcb.my question is whats is the cubic board and how it work on main controller !?
      • teckat
        • 16083
        [ATTACH=CONFIG]17215[/ATTACH]
        Send Expansion PCB aka (RESOLUTION CONVERSION. PCB )
        To enable the Universal Send Function is as follows:Send Expansion Kit-A1 Installation Procedure
        1) Place the Riser PCB into connector J1013 on the Main Controller PCB
        2) Place the Send Expansion PCB (aka Resolution PCB - Part number FG3-2764-000 or sales item number 7633A001AA) in connector J9003 on the Riser PCB
        3) Go to service mode COPIER>DISPLAY>ACC>SEND to check the Send Expansion PCB status
        A) If "0" is displayed the Send Expansion PCB is not recognized
        B) If "1" is displayed the Send Expansion PCB is recognized
        4) In service mode COPIER>OPTION>BODY>UI-SEND check the value is set to "1" (Default is "1"). If the value is set to "0," change it to "1" and exit the service mode
        5) Reboot the machine
        6) The Send Screen will be now be displayed on the Operation Panel
        Note: You must have System Software Version 51.02 or higher for the Universal Send Function to be available.
        • oommiiddaann
          • Feb 2012
          • 34
          thanks for your usefull answer teckat !!!
