E 0677-0010 whit imagePASS A1.
  • Ingranaggio_rotto
    • Oct 2010
    • 274
    Hello everyone ...
    I have a iRC-ADV 7055 with imagePASS A1 which often error code E 0677-0010.
    Although I upgraded the machine Sistem, this annoying code continues to appear .....
    Suggestions?
    Thank you.
  • teckat
    • 16092
    Re: E 0677-0010 whit imagePASS A1.
    Originally posted by Ingranaggio_rotto
    Hello everyone ...
    Suggestions?
    Thank you.
    check CPU Fan inside the imagePASS
    Service manual description of error code: E677 0010 00
    Failure in Print Server. Failure was detected in operation of the CPU fan on the print server--
    or-------------------
    point to note----
    IMG-CONT setting on the imageRUNNER ADVANCE must be set to 3 first and the printer re-started to confirm the setting is still set to 3 before the imagePASS is attached.
    If the imagePASS is attached with the IMG-CONT set to 0, there may be issues and you may need to re-install system software.
    To verify or change the setting:
    Enter Service Mode, Press * Settings/Registration, then 2& 8 simultaneously, then * Settings/Registration.
    Choose either Mode List or Mode List Classic.
    COPIER > OPTION > INT-FACE.
    IMG-CONT must to be set to 3.
