Imageclass 7480
  • copygirl
    • 75
    [Electrical] Imageclass 7480
    We have a Canon Imageclass 7480 that will not recognize the print system. I also have a working Imagerunner 2022i. I wanted to change out the Main PCB and don't have a parts breakdown. The two PCB's look the same and most of the numbers on the boards are the same. I realize that the DIMMs and the ROMs would have to be swapped around but are they really the same? It seems that it would be unlikely that they are alike, but could someone please tell me whether or not they are the same PCB? I didn't want to order one if I don't need to. I appreciate any help I can get with this problem.
    Ginger
  • Northwestservice
    • Jan 2011
    • 140
    Re: Imageclass 7480
    i to have an ic 7480 with no print or scan. i had bad main pcb, replaced it and then found out in order to get the settings back i have flash the firmwear and then was told the firmwear is not avalable??? so now i have a parts copier
